Got the CAI fitted, (complete with TB heater bypass) but got a major problem, the aluminium pipe it came with came it 2 lengths, if I fitted it as a sri with just the shorter length and it just sucked in hot air from being next to the engine, so I added the longer length, however it now leaves the filter right behind the fan, which draws hot air, and feeds it right into the filter.
So my questions are, where can I get some more lenghts of pipe?
And is aluminium the best material for pipe? as metal conducts heat, so wouldn't it warm up the air? Should I replace the whole pipe with something else?
