FOIL????? IS A CONDUCTOR DO NOT DO THIS YOU WILL SHORT OUT YOUR ELECTRICSKalsius said:Agree you shouldnt have many issue with a simple bucket and water job, if it happens next time it may be worth having a look under the bonnet when asap after washing and having a look to see if there are any runs of water near the electrics.. If you do suspect an area, the time after, put some foil round the exposed electrics and then see if it still happens. Might have to work through and check each as a process of elimination.
