ok guys, i'll post this here if a mod could move it, my washers wern't working so i went to investicate, turns out there was a LOAD of gunk/crap in the mesh of the motor, so i decided to take some pics while cleaning it out and do a lil walkthrough for people!
first off, prop the car up, using which ever method you prefere, i just used some bricks, worked a treat,
so now what i did was remove to screws from the bottom part of the mud gaurd, this loosened it enough to pull like in the pic,
now if you look up behind the guard you will see the washer reserve, the motors are the to black circles as seen in pic below, the one nearest the drivers seat is for the back, so whichever you need to clean with a screwdriver, prop the motor out, comes off altogether, will only b hanginig on by the plug into it on the top, which you remove, and also the water feed pipe, if you have trouble removing this heat with boiling water.. and also be warned that whether is in the reserve will flow out and get you WET!!
this is the motor here, the big tube on the side is where all the gunk in the mesh will be, scrape out as much as you can, then using boiling water to allow you to get the rest if its not shifting, the water should run clear from the big one to the small tube on the side!! once clean repeat the process in reverse to put back and admire your hard work and splashing water!!!
one tip is to hold the indicator for a good long time after taking this all apart to allow the water to travel back up to the washers.
