1 - 3 of 3 Posts
Finally found time to replace my sheared bolt today, got the hub off, however whilt I had it under the press to remove the old bearing I managed to destroy the hub.
Rang round local scrappys, got hold of an entire hub, however they had outboard discs, instead of the inboard discs mine had. The did fit on ok, and I'm now back on the road, however the car I got the hub from is a T-reg, mines only an S-reg. Why are they different on the same model?
if i remember rightly the early 98 models were made slightly differently to the late 98 onwards including the removal of the captive rotors and such whatever relevance that has :roll:
1 - 3 of 3 Posts
