Right then.
1. Pop out your dimmer dial with a small flat head screwdriver. Now undo the wire harness and undo the clips to take the 'face' off
2. you now should have something similar as below (without the LED as that is what i have done earlier, you should have the original one on a black plastick post)
3. Now you need to pull the circuit board out you will need some long nose pliers for this. It is a tight thing so will take abit of pulling to get it out. also make sure you pull the wheel out of its hole on the side.
4. Now you need to de-solder your original led and remove the black holder for it amd solder your new one in its place.
5. Once you have done that i would recomend plugging it in the car to make sure it works if it does then re-assemble.
