Hiya,
Having to replace my discs at the weekend following MOT failure. Looking for some advice and hints. I have captive discs and was wondering if I need special tools etc or if it is, in theory, a case of remove the caliper, remove the 4 bolts that go through the front of the disc & hub cover then remove the disc or is it a heck of a lot more work than that... found a how to on-line but it concentrated on the other type of discs and merely mentioned the captive ones and that they are different!
(Wheel bearings seem quiet and there is no movement in the hubs so I'm hoping to avoid replacing them)
thanks in advance for any input.
