i decided a long time ago to write a post like this
having had quite a bit of experience modding the coupe,iv decided to write the common sense modding post.how many times have you bought a mod only to find it either doesnt fit or it wont work with summat else you did earlier.so i thought this would be the perfect place for people to write down what they experienced.possible material for a sticky here.....so here's what i know so far
AUDI TT STYLE GEAR BOOT-looks fantastic but what they dont tell you is it wont work properly with a SHORT SHIFTER and looks crap with a short gearstick.its designed to sit up whereas it cant with a short stick!!
STEERING WHEEL COLUMN ADJUSTER-chrome caps look great BUT they dont tell up the plastic end is actually MOLDED on to the metal so you end up hacksawing/dremmeling off and so its NOT reversable.
HANDBRAKE COVER-this is all one piece so if you want to change handbrake cover you have to measure it and cut it off and therefore its not reversable!
OBX RADIATOR HOSES-iv found they are much more flexible when hot hence they constantly leak at the end and just a clip will not stop them you have to seal them too.upping the bar pressure with a different cap probably doesnt help
L.E.D REAR LIGHTS- please note your cruise control will NOT work with LED'S as rear lights.they will need resistors wiring it to make your cruise work.please note this doesnt apply to new lights without led's they wont affect your cruise
TUSCANI MISSION PLATES FROM MIDNIGHT WOLF-if you have it in silver if you put the slightest smallest thing on it it will scratch to hell(ask faz)this also applies to anything done in brushed alloy by midnight wolf including e brake covers
